Hi all, need advice on the followig:
I intend on fitting a garden tap which could supply both hot and cold water.
this would be achieved by taking a feed from both hot + cold pipes under kitchen sink through outside wall then add a check valve? to both feeds before they meet at a T which would then connect to the garden tap.
I already have the garden tap kit which consists of a self cutting thingy and a length of hose to run to the tap, however, what I'm thinking is to use another self cutting thingy for hot water pipe then changing from hose to compression fittings on exterior.
The reason for doing all this is so I can have cold water for garden use and the option for hot/warm water for pressure washer use, but before commencing I thought I best seek advice first.
My main concerns are if this could have a negative effect on either the boiler which is a Potterton Promax Combi HE Plus, or on the pressure washer which is a Karcher K3550.
Any advice/guidance on any of the above greatly appreciated.
Thanks in advance,
Adrian.
Thanks in advance,
Adrian.
