hot cold shower
23 Oct 2007
Just moved into a new house and the shower (gainsborough 9.5s) runs hot for about 40secs then there is a click (thermostat I guess) followed by cold water . It then runs in cycles of hot/cold indefinitely. Please help. Have looked at several forums and apparently other people have had issues with this shower too.
If you live in a hard water area I would think it is the heater can scaled up making the shower overheat and cut out, then it will cool and come back on and so on and so on.
Thanks for your help. Is it something you can clean or is will we have to buy a new shower?
first thing to check with an electric shower going hot/cold is remove the shower head turn to fully hot the flow should be slow.
then turn to cold the flow should be fast is this happening ?
Had to go away for a week. Just checked. yes it is slow with the hot fully on and faster with the cold only. Where next?
