Hello,
We have a Baxi duo tech 40 HE and two weeks ago we noticed that one of our downstairs rads was cold, the next day we lost heat from two more in the lounge. This continued until we lost 6 radiators downstairs.
We had our whole system balanced in January and managed to get our kitchen rad working which hasn’t worked for years.
A plumber suggested an airlock or new pump so left me with instructions on how to try and clear the airlock and a quote for the pump. His other suggestion was a chemical flush.
This is what I’ve done so far
- Turned all rads off and the furthest rad upstairs on full, waited for it to get hot then moved to the next. Only 2 got hot so I….
- Changed the pump head
- Cleaned the magna clean
- Then the boiler kept losing pressure so changed the pressure release valve
- Disconnected one rad downstairs to check if the flow was full of gunk but the water was totally clear.
- Since the new pump I can get 5 rads upstairs lukewarm. 2 remains cold.
- Or I can 1 rads hot and 5 cold downstairs. I have to turn all the rads off upstairs or downstairs to get heat in the other.
- I’ve tried to release a possible airlock following the new pump installation and bled the rads.
