I have a hot tap that works finer most of the time, but in the middle of the night, or early in the morning, it screams loudly! I can turn the tap to increase or decrease flow past the point were the screaming starts, but it's getting worse. I've changed the washer a couple of times, and it stopped each time for a day or two.
It's a mixer tap, fed by a combi boiler. Whether the cold tap is on or not makes no difference, the hot is noisy at anything between a trickle, and full blast.
Before I take the tap off and dismantle it, is there anything I should look for? It's an old style tap, with a nut which I believe tightens packing (I might be wrong), however tightening or slackening this nut just makes the tap easier or harder to turn, and doesn't affect the flow, or noise.
