hot tap
3 Nov 2005
Bristol
my hot tap in my bathroom has gone from normal flow to almost a dribble is this a simple washer problem :oops:
its the dead pigeon in the cold water cistern....its sunk and its bloking the outlet !!
Or a bat, or squirrel...
...Or it could be debris, usually foam insulation from the recently fitted hot water cylinder...
...or a knackered valve. Does the flow improve if you "lift" the tap head? Is the tap harder to turn than normal?
