hot tub fittings
19 Mar 2007
Hi all.. We are having a hot tub fitted we need about 50 meters of 4.0mm core swa {armoured cable}.. a 16 amp outdoor installation switch. 16amp mcb maybe? and needs to be certified. we have space in the fuse box for the cable to be fitted. WORK NEED TO BE DONE.. core cable from the fuse box from the front off the house which is in the garage fuse box is on a out side wall so eas to be drilled. cable run about 40 meters from front to bk of house connected to the isolation switch then approximately 4 meters of cable off that could ant please give me a estimate price thank you
forum rules said:
9) Please don't ask costs / prices (Ball park figure). Get several quotes, then you will know for sure
It depends on several factors:
Your location, Access to job, material costs, labour rate etc, any prices mentioned should not be relied upon / maybe old prices
Please get several quotes
There is no such thing as an "average" house (since your requirments will be different)
As one poster commented
can't see it, can't quote it
Forum Rules
