So i'm about to start a new project to build a decking that will be used to hold a hot tub in the future. My question is, what do i need to keep in mind when doing the job?
I assume the cable whilst needing to be rated for the current must be armoured?
How deep does the cable need to be in soil/garden?
How deep does the cable need to be if under concrete paving flags?
What if i use PVC tubing, does this change anything as its protecting the wire?
Should the PVC tubing have drain holes drilled on the under side?
I assume an isolation switch is necessary for the hot tub and this needs to be minimum 2 meters away from the tub?
I assume it will need its own circuit from the consumer unit OR fuse box?
I guess an RCD will be required at the consumer unit/fuse box?
Is IP54 ok for anything outside (i.e. the isolation switch)
If the isolation switch is mounted under the decking (i.e. you have to remove a hatch to get to it) is this ok? Can it then be less than 2 meters from the tub?
Any other recommendations?
Regards
Matt
Regards
Matt
