I have just replaced the central heating controls with a Drayton Lifestyle with new programmer and wiring centre. The original set up did not have a room stat and the mid position valve(Honeywell) had never worked. It now seems like the mid position valve is working the wrong way round. I have checked and double checked the wiring and everything is connected how it should be. It almost seems like that if I remove the valve and turn it through 180 degrees it will work fine. The other option would be to reverse the wires to the mid position valve, but which ones. Anyone have any ideas?
