hot water and pressure problem
5 Jan 2004
I have a gas, worcester 240 rsf combi boiler and recently had a leak from the bypass assembly. i drained the system and canged the whole assembly. Now its back together i filled it back up to pressure and now when i use the hot water it only gets hot if i put it on to not more than a trickle, if i open the tap anymore the water comes out almost cold. Also now when the heating is on the pressure gage goes right up to about 2.5bar when it gets hot (starts at 1.5) is that normal? Does the small adjustable screw in the bypass assembly need adjusting?
There's a Worcs expert who visits sometimes - try reposting with the boiler details in the title.
