Hi, everyone,
I was wondering if someone might be able to comment on whether the following setup would work?
Every combi boiler has a minimum required flow rate at which it fires - if the flow is below this number (2.3-2.8 l/min or so) the boiler doesn't fire in order not to overheat.
However, this creates the issue that if the tap is only half-open, the hot water never comes - it stays cold because the boiler is not working. But if you have two taps half-open, then everything works fine.
To give an example, when washing up in the kitchen sink I don't want water splashing all over, so I run the tap just enough for it not to be too strong. At this rate, the flow (as measured by the flow cup, hot water only) is just under 2 l/min...
How would I go about making the boiler work even when the flow is this low?
I was thinking of fitting a flow gauge onto the hot water supply line to read the current flow. If the flow was within a range of 0-3 l/min, the gauge would activate a brass pump that is connected to a loop branching off the hot water supply and returning not sure where - maybe to the waste drain (I know it's wasteful...)?
What this crazy setup would do is effectively act as a second half-open tap - when the flow is low, it would boost it, thus making the boiler fire and heat the hot water...
So, would this work?
And if so, what specific parts/brands would you recommend for the flow gauge and for the pump?
Many thanks!
Many thanks!
