I have a Chaffoteaux et Maury Britony Combi 80 and the CH part works fine. Over the years the DHW has got cooler and cooler (i have noticed this because i have had to gradually turn the thermostatic mixer shower up to near maximum over time.) I imagine this has something to do with the secondary heat exchanger. Last week, however, my hot water went down to about half its normal heat.
I took the secondary heat exchanger off and descaled and flushed. I put it back on and i think it helped a little but it's still not as it should be. Do you think i need to replace the secondary heat exchanger altogether or is there some other part that might cause this sort of problem?
As i understand it, if there was a problem with the DHW thermistor or the control PCB, then the reduction in heat would be as a result of a reduction in heat in the primary circuit. But this seems to be fine. The flow coming out of the DHW heat exchanger is also fine so i don't think it's blocked or anything. This only leaves the secondary (DHW) heat exchanger unless someone can suggest something else to try before i waste £100 on an unneccesary part.
