hi all can anybody give me a reason for my central heating cold water tank is full of hot water causing a lot of condensation in the loft it apears
to come out of the exspantion pipe blow off when the pump comes on it starts to feed water in to the header tank slowly but enough to make the water hot can any one give me advise i think if i extend the pipe up another 2 ft higher will this be sufice or is their a valve i could put on the end of the pipe so it will still blow off on to much preasure but stop the water feeding into the tank all the time the heating is on thanks nobby
