Hi everyone. This is my first post here and I'm hoping someone can help me with my problem.
I have Ferroli Optima 701 wall mounted, room sealed, gas combination boiler which is about 5-6 years old. (I have the online manual if anyone needs to look something up). Up until yesterday everything was fine but now I'm having a problem with the central heating side of it. When I turn on my thermostat, the fan starts to run, the boiler kicks in and everything seems fine, but then after about 2 minutes the boiler just stops and the flame just goes back down to it's normal size. When I wait a while and try again, after a couple of minutes the same thing happens again.
My hot water in the meantime is absolutely fine. Obviously this leads me to believe that it's not a pump or a fan problem but something that works on the CH seperately from the hot water. I hope I've given you enough info to help.
Thanks in advance.
Thanks in advance.
