Hi to all
I have a problem with my parents central heating,When the hot water is turned on at the timer clock the 3 port valve operates,pump runs and boiler fires up and the water gets hot.
If I press for central heating i hear the pump run for a nano second,the 3 port valve moves and sadly the boiler does not run.
Ive replaced the timer clock and the problem remains.
Ive looked at the wall thermostat and that clicks and apears to switch voltage.
Any one got any ideas? could the 3 port valve or stat still be faulty?
