Hi
I've been having an ongoing problem with our combo boiler. The hot water only works randomly. Most of the time there is no hot water. The heating seems to work ok. Occasionally a hot water demand from a tap will cause the rads to heat. We also get quite a violent banging from the pipework downstream of the boiler. Our local engineer diagnosed a faulty diverter valve which he has now been replaced with a new one but it has not cured the problem.
Any ideas ? Is it likely to be the electronics in the boiler sending faulty signals ?
