yes, I've had a Profile. It's a big iron boiler so it takes a fair amount of heat to warm up the iron, and then afterwards the heat just oozes out and warms the garden, and the ceiling of the room it's in.
You have a big cylinder, and once a day might be enough, but I'd set it to run for an hour in the morning, starting half an hour before you get up, and the same in the evening, starting half an hour before bathtime. it will not actually run for as long as that, because as soon as the cylinder is up to temp, it will stop calling for heat. A modern cylinder can nominally heat up in 20 minutes but I find in practice it takes longer.
Set the timer so it is off when you want to be asleep, because a Profile is a bit noisy, especially if the fan bearings are worn out.
Your modern cylinder will stay hot for a couple of days if you don't use the water. I don't actually know how long, but heat loss is very slow. I've had a hot bath after working in a house for a weekend when the power has been off since Friday. 210 litres will give about two baths or several showers.
Do you have a system filter on your boiler to catch sediment particles? An old Profile may have quite a lot of corrosion collected in the bottom. If you are a keen DIYer a chemical clean is very easy and cheap.
