I just discovered an hour ago that our hot water cylinder is leaking / has burst (apparently from pressure -- the insulation has blown out at the spot of the leak). I had actually gone into the airing cupboard an hour earlier, and had noticed that it was really humid in there and two towels hanging on/near the cylinder were very wet -- assumed my wife had washed them and hung them there to dry. When I went back an hour later, noticed the carpet was wet, and discovered the leak. The hot water heater was possibly on at the time of the burst -- it's on from 6-ish until about 9 or 10pm.
The thing is, on Wednesday I replaced the kitchen tap with a single outlet mixer tap. The hot water pressure wasn't sufficient for the tap to perform well, so I was going to switch it back with the old one but hadn't got around to it. Is it possible that the cold water mains pressure overpowered the hot water supply enough to weaken and burst the tank (it is possible that the mixer tap was being used when the leak occurred, as we were in and out of the kitchen all evening).
Thanks for any advice!
