Hi guys.
We have a vented hot central heating system. The hot water cylinder have the hot water connection on the top with a 15mm tee off for the shower. We are going to add a pump to the system but want to plumb up using 22mm piping which is the preferred way.
There are the connections for the cold feed and boiler feed. On the right hand side about 3/4 way up is a blanked connection. I am hoping that this connection is a factory fitted one designed for connection of a shower feed. The tank insulation looks factory finished and not chopped about.
Question is, am I right in thinking I can use this connection to feed the shower pump?
cheers
cheers
