Hi
I'm hoping someone out there can help me.
I have the following set-up which whilst I've never fully understood has always worked fine and energy bills have been low so not been fussed!
Recently though the timer in the airing cupboard next to the hot water cylinder has been making a buzzing sound intermittently.
Right, so downstairs there is the boiler and a programmer (Landis & Gyr RWB200). Upstairs in the airing cupboard is a hot water cylinder (believed to be indirect based on web diagrams, looking at pipes etc) which has a Honeywell thermostat and an electric immersion on it. Next to it is this second timer unit - a Randall ET009 "heatswitch" as it says on it. I've not been able to find any instructions for it so assume it is old, although digital. It runs off a fused switch and I am assuming that the cable which runs to the immersion on the cylinder is connected to it at the back (disappears off cylinder into same wall unit is on).
I use the downstairs L&G programmer/timer to set hot water and hot water¢ral heating and (it sounds bad but...) have mostly ignored the timer in the airing cupboard upstairs as irrelevant as up until now I've only needed to turn the Randall timer on every now and then for the immersion. I can tell it's working as it immediately starts making some noise/heating the water.
So this Randall timer in the airing cupboard has time controls, a manual change button, a red indicator light (although the digital display shows off and on etc) and a big black on/off switch. It's the black switch I use to turn the immersion on.
The buzzing noise seems to be from the timer and not anything else and seems to only occur when the digital display shows "off". I have checked for loose wires etc from the fused switch into the Randall timer but not taken the unit off to check the back). I tried turning it off from the fuse box but discovered that the fused switch it feeds off also powers the shower so the test of using up the hot water by showering and seeing what happens didn't work out.
To get rid of the buzzing I've switched the timer unit off at the fuse box to reset it and not set any of the timings and just left it "on" using the manual change button (but big black switch is off).
A week or so ago I noticed the red light always seemed to be on, which worried me (energy costs) so I tried to make it go away! The noise seemed to start after I played with the time settings to make them match the L&G programmer downstairs (next to boiler). Also, I'd better confess that I can't remember what the time settings were set to before - perhaps it was set to always on. Like I say, as I didn't really understand what the box did I just left it as the previous owners had.
So, after my tinkering/causing problems for myself I am wondering: a) does the timer in the airing cupboard serve any purpose other than as a switch for when we need the immersion on? b) if so, can I (or, let's be honest, DIY competent dad when he is back from hols) just replace it with a switch? or c) am I better off replacing it with a like-for-like timer unit?
Thanks very much for any advice anyone can offer - I can post any photos or extra info as needed.
Thanks again
Ian
Thanks again
Ian
