Hi
I am currently installing a new indirect hot water cylinder in my airing cupbaord (in bathroom). I hae had to alter the pipework slightly as the new cylinder flow, returrn and cold feed positions were slightly different, but my question is...
the cold feed should go into the cylinder at a very slight fall... but with mine, the pipe going into the cylinder (about 150mm long) doesn't stay at a fall !! this pipe goes to a tee, which then tees off to both the cold feed (from the cold tank_ and a drain valve is out of the other outlet. the cold feed pipe joins a gate valve about 4 feet up and then carries on to the tank. why does the pipe not stay at a slight fall when i leave it?!!
any help... should i be worried?
