Need to replace the hot water cylinder cos its just about to start leaking big time..
However I see there are loads of diffrent ones...direct , indeirect , vented and unvented...
So let me discribe my system then someone could tell me what I have.
1 hot water copper tank fed via the bottom from a cold water tank.
The tank its self has the following pipe work outlets..
to the rear of the tank two pipes these feed to the the boiler so im guessing these bring hot water from the boiler into some sort of coil (im guessing this is the indirect part)
Two other pipes are also present...one coming out the top (feeds the hot water taps ) this one has a T in it and an overflow into the cold water storage tank.The other pipe is at the bottom and feeds from the cold water tank.The electric water heater fits in the top of the tank but im guessing thats a standard thing.
Relly the only bit of info I need is what type of system is this Vented or Unvented?
Also the tank im guesing will be 10 years old or so will i need to change the fittings as the threads and sizes might be diffrent??
Cheers for any help in advance.
FLY
FLY
