Hi, I shut the hot water off today with the gate valve that feeds the cylinder, changed the bath taps went to turn the gate valve back on and
nothing the red handle just keeps turning i think the spindle may be broken, so i thought just replace the gate valve only when i came to drain
the cylinder the drain off valve does not work i unscrewed the square nut fully and it looks like something has sheared off inside. Can someone please advise best, easiest method of draining down the cylinder so i can change the gate valve. I can drain the large header tank via the shower.
thanks in advance.
Alan
thanks in advance.
Alan
