Hot water cylinder
15 Dec 2005
Wondered if this brilliant site could help me. I am refurbishing a property which has an old floor standing boiler, with gravity hot water (via coil to cylinder) and pumped heating. I want to temporarily remove the indirect cylinder, but be able to keep the heating on (hot water does not matter). My question is can I remove the indirect cylinder, disconnecting the flow and returns where they join the coil and cap them off? Will I still be able to run the heating? - Would it be better to link them together to keep the hot water circuit going?? - and can this be done. Basically I want to be able to run the heating for now, with no cylinder in place.
Hope this makes sense - any help would be gratefully received
You can do either regarding capping or making a loop BUT make sure you leave a vent pipe and cold feed from tank in loft :eek:
Thanks so much for your response - can I just ask one more thing - can I use plastic Hep pipe to link/cap flow and return (as it is temporary) - or will it melt as it will be fairly close to the boiler
thanks again
thanks again
I don't use plastic but i am sure if you refer to manufacturers instructions it will tell you you can providing it is 1 metre from boiler i think ?
Guest say NO CAN DO for gravity feeds ...... But it might be good to do fer a laff :p
Sorry im not sure if you are being serious - are Guest a make? - Are you saying do not use Hep to cap off or create loop? - Im a bit confused now - Please help
Or are you saying that I can not cap/loop the flow /return at all?
http://www.johnguest.com/
The site says don't use their plastic for gravity fed systems.
I'd stick to copper just to be safe (Its bloody hot that water) ...... 10 mins to whack in a quick U bend...... could use elbows if you haven't gotta pipe bender handy :D
Thanks - yes think I will use copper - sounds a safer bet
