I want to replace our hot water cylinder for a larger one on a vented, indirect, 2 motorised system.
I'm confused as it appears the boiler flow enters the cylinder at the bottom in 22mm pipe since it has a motorised valve on the pipe before it enters the cylinder. The pipe above it in 15mm appears to be the boiler return.
Is this correct, should the new cylinder have the flow above the return pipe. There is a pump which tees off to both valves if that makes a difference.
