i want to tee off the hot water cylinder for shower, how far up the pipe will the hot water reach. basically what im trying to say is if i tee off just into the loft and then pipe across to the shower will it gravity feed up the pipe enough to get pressure.
thanks for advice. just one more thing. the pipe run for the hot water will be roughly 4 mtrs, would that normally be a pump job or is that ok for gravity fed bearing in mind it is just normal size hwc.
