hot water cylinder
31 Jan 2007
Lancashire
hello
i have a hot water cylinder that needs replacing. the water is heated by the immersion, there is no central heating. i cant find a tank with just a cold feed and a hot supply with a hole for a immersion. the only ones i can find is the ones with the central heating connections. can i by one of these and blank of the holes?
if so where from?
many thanks chris.
You can fit one with a coil for central heating connections and there is no need to cap off the connections.........the water is heated indirectly so no water will come out!
You need to ask for a 'direct cylinder' The one you describe with central heating connections are called 'indirect'.
You can get these from any good plumbers merchant ;)
gas dont you find that direct cyls are hugley more expensive than indirect?
I do thats why I do what harrow suggested
Yes corgiman, but i was just letting op know what to ask for as he said he couldn'y get one :)
gledhill will build you what ever spec you want they are in Blackpool thats where i get mine made at.
