Can any one explain to me the difference between the older cylinders, which used to be covered in yellow or green foam and the modern ones which use blue foam? I know that the allowed heat loss has been tightened up but the insulation material seems to be identical, apart from the colour and thickness has not changed. So how are they achieving the lower heat losses?
