Howdy,
I have a query about the hot water feed for a power shower pump. Over the festive period the pump we currently have decided that it has had enough and leaked all over the airing cupboard floor, which was nice. The leak is terminal and so i have bought a replacement pump which i'm waiting to have delivered.
Currently the hot water feed for the pump is taken from the top of the hot water tank (pump sits next to hot water tank in airing cupboard). I'm not sure if an surrey/york flange is used or not but will try and take a closer look tonight.
In the fitting instructions for the pump and also having spoken to the tech support people at NewTeam they are telling me this is not the way to do it and i should disconnect and cap the current hot water feed from the top of the tank. A t connection should then be installed in the expansion pipe / hot tap feed about 6-12" below the top level of the hot water tank and feed the pump from here. This of course will add cost the installation if the current plumbing can not be used. Can anyone explain to me why it has to be done in the suggested manner rather than using the current feed from the top of the tank?
Thanks and regards,
Mark
Thanks and regards,
Mark
