I had a Combi boiler installed about 6 months ago, and have just had my new bathroom fitted.
I now have the problem that when the shower is running if i operate any other hot water tap the shower cuts out (due to the thermostatic valve).
The flow rate of my boiler should easily cope:
DHW Flow Rate (Delta T @ 35) 13.5 litres/min
Also the hot water pipe leaving my boiler is 15mm would this this restrict my flow? and should it be 22mm
My bathroom fitter believes this to be down to the Cold water supply pressure to the house, but i am not convinced as i can have have several cold water taps on at once.
Any other ideas?
Any other ideas?
