My first post here, I hope someone will be able to help me out or point in the right direction.
I have moved into new place, which have very old combi boiler, I think it is from Chaffoteaux, but i don't know the exact model. Plumber who was in the property few months ago said it is at least 15 years old and they dont produce these anymore, it is magic that it survived this long.
Boiler works ok for central heating, but when using it in the shower water does not mix properly, it is either very hot if you have hot water tap open or very cold if you reduce the hot water flow. I noticed that boiler fires on when hot water flow is at full, when you reduce it to half, it switches off and after 2-3 min water gets cold and you have to turn hot water tap fully open to get hot water again (after another minute or so). When hot water is fully on, it completely overtakes cold water and you get very hot shower, which is impossible to use. If you reduce hot water flow to half, as I mentioned earlier boiler switches off and you get cold water after about 2 minutes. This makes impossible to take shower, you are either getting very hot or very cold water out.
I was planning to change the boiler anyway, but thought I would ask here whether the problem is definately with boiler or maybe with shower head or something else? Water pressure seems to be good.
I hope i could explain the problem, thanks for your responses!
