- Joined
- 23 Aug 2007
- Messages
- 88
- Reaction score
- 0
- Country
Hi all!
Right, about a year ago I had to replace the diaphragm on my boiler (Ravenheat CSI/HE) because the water was running hot then cold (and eventually just cold). It worked and I've had hot water to this day!
However, just recently the water has been only warm - warm enough for a bath but not as warm as I'd like it. Baths used to be really hot before and I had to add cold to get it right. I've now upped the boiler temperature but it hasn't made much difference.
I've checked the diverter valve shaft and microswitch and they're fully extended. The water is perfectly consistently warm - no fluctuation in temperature.
I also tried the old: leave the heating off, run hot water for ages and then felt to see if the central heating pipes have warmed up to see if hot water is leaking into there but it isn't.
Any ideas what this could be? Cheers people!
