Hi all
The fitter has just installed a Potterton Gold HE combi. It has two Honeywell motorised valves (one for the central heating and one to heat the hot water cylinder) and both connected to the heating return. Both of these valves operate on the CH setting on the boiler. The hot water setting just feeds the HW to the kitchen sink. So in effect I have HW from a cylinder as well as HW from the boiler.
All are controlled by a Honeywell 10 way junction box, a Danfloss Tempus 7 programmer, room stat, cylinder stat.
All works fine except the hot water to the sink only activates when the programmer HW is switched on. This is the switch I just want to heat the HW cylinder upstairs as I want the HW to the sink to be on all the time when called for by turning on the tap.
What this means is that if I want to use the HW in the sink then I have to either turn on the HW from the programmer while the boiler control is set to CH/HW, which starts heating my cylinder or I turn on the HW on the programmer and set the boiler control to HW only which means I have to manually switch it back and rester the programmer when I want to heat the cylinder and use CH.
I'm sure it's a wiring fault but it's driving me mad!
Any help would would be great?
