- Joined
- 18 Aug 2015
- Messages
- 68
- Reaction score
- 4
- Country
Hot water coming out of the hot water storage cylinder into upstairs radiators after heating/HW turns off and running out of hot water in the mornings.
I have a Glow Worm 24HX Condensing boiler on the ground floor with a pump in the same cupboard, a hot water storage cylinder in the airing cupboard upstairs (Kingspan 1500 x 450 grade 3, 162 Litre. cylinder) in the eaves area I have another pump (both pumps are Salus MP200 domestic circulating pump). Upstairs I have two Drayton 2 port Zone Valves ZA5, one on the hot water supply to the hot water cylinder and one to the central heating supply.
The hot water and central heating is timed to go on in the afternoon 4pm to 1030pm every day and has been working fine for the last 7 years, I think the whole system is around 11 years old.
One evening I found that the temperature of the water coming out of the upstairs shower was warm and I couldn't get it to go hot, no matter how much I adjusted the shower control.
It appears that when the heating and HW goes off at 10.30 pm a couple of upstairs radiators (2 in bathroom and 1 in bedroom) stay on hot for an hour or so when the others have all cooled down. I have checked the boiler and it goes off at 10.30 pm.
I'm wondering if this is a zone valve ZA5 problem either on the HW or heating where the
hot water is going through from the upstairs hot water cylinder to the radiators.
Can anyone let me know they think this is a zone valve problem, which valve is is suspect, heating or HW or anything else ?
I'm looking to change zone valve heads soon but I am trying to find out if it could be anything else causing the problem, before I make a purchase, in case it does not cure the problem.
Many thanks.
Mike
Many thanks.
Mike
