Hello. I am having a problem with the overflow from my hot water header tank. The header tank appears to be filling up from the bottom every day and overflowing, through the overflow pipe. I thought it was a corroded ball cock but having replaced that I realised it was filling up from the bottom.
I assume that this means the water is coming up from the HW tank (the header is in the attic directly above the HW tank).
We recently had a power shower fitted and think that there is now a problem with the pressure in the system. I knew it was a bad idea!
Our CH is open vented from a wall mounted boiler.
Any ideas or insight is desparately needed
Thanks!
Thanks!
