HI CAN YOU HELP-
I HAVE A WORCESTER R29 HE CONVENTIONAL CONDENSING BOILER, IT WORKS FINE EXCEPT THAT RECENTLY THE OVERFLOW RUNS WATER FOR A FEW MINUTES WHEN THE C/HEATING HAS BEEN ON FOR FOR A WHILE. I HAVE ESTABLISHED THAT THE F+E TANK FOR THE C/H IS BEING FED WITH HOT WATER ALONG THE 15MM FEED PIPE ?
THE WATER LEVEL IN THE TANK WAS A GOOD 3 TO 4 INCHES BELOW THE OVERFLOW OUTLET SO IT HAS BEEN FED WITH A FAIR BIT OF HOT WATER.
THE F+E PIPES ARE CONNECTED TO THE FLOW BEFORE THE PUMP - ABOUT 12" BEF0RE IT TO BE EXACT. THE 22MM EXPANSION PIPE IS RIGHT NEXT TO THE 15MM FEED PIPE BUT THIS PIPE GETS BARELY WARM WHEREAS THE FEED PIPE GETS RED HOT....I HAVE DRAINED THE SYSTEM AND CHECKED THIS INTERSECTION FOR A BLOCKAGE BUT IT IS CLEAR.
AS FAR AS I CAN SEE THE SYSTEM IS AIR FREE.
THE PUMP IS 2 SPEED SET TO 2.
RADIATORS GET NICE AND HOT.
HOT WATER FINE.
ROOM STAT ONLY SET TO REASONABLE LEVEL.
ANY IDEAS OR SUGGESTIONS.....!!!!!
HOT WATER FINE.
