Hi - need help related to my old potterton regular boiler system. As I understand there is Potterton gas boiler which turns on based on the timer or whenever I want to manually turn on the water or CH. Also there is a water cylinder with immersion heater as a back up and its electric switch is constantly been turned off as I was told it is only needed in cases the gas boiler does not work.
Now the problem is that when HW is turned on, gas boiler starts and no issues with the temprature of the water. However as soon as CH is turned on, there comes a sound from the boiler as if the electricty is passing and gas boiler only turns on after few minutes however that electricity sound keeps coming throughout the CH session and even after the CH is stopped. This things causes the HW to be extremely hot and I cannot see tempratures coming down even after the CH timer switches off.
My guess is that is something to do with the electric immersion heater turning itself on (although its main electricty switch is off) and does not turn off keeping the water extremely hot.
Any ideas and thoughts? - thanks
