not sure if im posting in the right section...
But I need some advice...
Im not getting alot of hot water through my taps.
The water tank in the attic is slow at filling, having observed... water level is really low... the water flows out but occasionally it will just stop and go etc.
hot water taps all around the house has very little water coming out as a result. (when the water tank eventually fills, I have hot water, but soon its all gone again)
Even the cold water sometimes gets smaller... I notice when in bathroom, when I turn on hot tap fully, then turn on cold tap. the hot water tap flows alot smaller... ie. its like the cold water is taking away the water from the hot.
also sometimes when I switch on the tap I can hear the pipes rattling (im pretty sure its the pipes going up to the water tank. its as though theres alot of air.)
Any ideas? Is this airlock? I thought airlock means no water coming out at all.
had a plumber who couldnt fix it, said its from the mains water supplier? but my neighbours seem to be fine
Many thanks
Many thanks
