We have an S-Plan unvented central heating/water system with a hot water cylinder. The boiler is set to come on twice daily: Once in the morning at 6:30am-8am (1 hr 30) and once in the evening at 5-7pm (2 hrs). The boiler heats the water and central heating at the same time.
I got up the other morning around 7:15am for a shower. so the boiler would have been on for 45 minutes. However, the hot water was tepid. I appreciate its been cold recently but I thought after 45 minutes the water would have been up to temperature. Im normally in the shower at 7:45 and the hot water is fine.
We just got back from the in-laws this evening and the childrenwere really tired so we decided to give them a bath around 6:30pm. Again the water was luke warm (not suitable for a child's bath). So we had to put the immersion on to quickly get it to temperature.
I think it could be a number of things but looking for pointers on where to start first???
In the summer, we turn down the 2 central heating thermostats.
Any help would be really appreciated.
- I heard that the radiators for the central heating may be out of balance. Could this be it? We did have TRVs fitted recently and I imagine the plumber would have had to play around with this. However, I always thought that with an s-plan system the water for the central heating just runs through the coil in the hot water cylinder which indirectly heats up the hot water in the cylinder.
- I read somewhere that it could be the balancing valve on the hot cylinder. But Im not sure where this is?
- Is the boiler temperature set right? We recently had it serviced and the engineer had set it to 65C so I don't think its that.
- Could it be the cylinder isnt insulated? Is there any way to check whether it is insulated? Im pretty sure it is, house was built in 2007. But I was tempted to put some insulating jacket on the outside and on the pipes too which are bare.
