Hot water keeps cutting out /radiators working OK (avanta +)
10 Sep 2007
Kent
Currently having problems with my boiler where the hot water keeps cutting out after about 4 minutes. The boiler's an Avanta Plus 35c.
The radiators work fine and will happily come on and off but when using the hot water taps it's fine for a while then shuts down the boiler and registers an error E7. Manuals not much help as it seems to be geared to the radiator system checking water pressure/pump which I assume are OK pressure's around 1.5bar and the pump is probably working ok as the radiators are fine.
Any ideas of whats likely to have gone wrong ? Does the hot water have a separate temp cntrol that may be tripping/any liekly blockage causing it to shut off (water flows through fine even if it is cold though)
Error E7:
Checking the pump spindle rotates is explained on page 29 of the manual.
As the pump is integral to the boiler, there is little chance that the pump is wired wrongly.
You can check that the pump is working by using a screwdriver or metal rod as a stethoscope.
The Avanta stores up to 16 error messages, so it might be worth checking all of them. How you read them is explained on page 55 of the Manual.
check auto air vent
e7 does point at the pump but if heating is ok maybe the p/hex is choked
how old is the boiler?
it all depends on what the boiler looks for to give that error message. I would assume that its basing it on the difference between the flow and return ntcs, as this is how most modern boilers work, and you have to remember that all the fault codes were tested and programmed on a boiler with nice clean water! So fault codes can often be misleading. If the boiler works fine in heating then its pretty likely the plate Heat exchanger is blocked. I don't know if there's any kind of filters fitted to this boiler in the hydraulics, if so this should also be checked.
