hi ya, I have a potterton 80 combi, When running the hot tap I get hot water fine but turning off the tap the boiler stays lit until the water in the pipe becomes steam and vents and the sytem locks out, most of the time it resets after waiting 5 mins for system to cool down but today as soon as I take it off standby (heating set to off) the boiler lights up as if the tap was running ( taps off, non dripping ), With the cover off a red light on the PCB is now on all the time, Is it a sticking flow valve??,if so can this vlave be cleaned out/greased or do I need a new one? Are they easy to fit?
Central heating works ok until the hot water locks it out, Anyway to disable the valve so I can just get the heating working.
cheers
S
cheers
S
