Hello,
I'm having issues with my hot water. I have an indirect system (boiler and pump serviced last week and all OK). Central heating works fine, but when I switch on just hot water (or indeed hw and ch) i don't get any hw. the pipe going into the cylinder coil thing gets hot, and the return pipe is cold. the feed pipes to the hot water taps though never seem to warm up when you run the hw though. i considered it might be an air lock and have done the thing where you use mains pressure from the kitchen tap to force water back up through the hw tap, but still nothing.
two questions:
1. should the feed pipes from the top of the cylinder get noticeably hotter when you start to run the hw as it starts to flow out of the cylinder
and
2. could there be a blockage in the coil itself meaning only a fraction of the coil is heating up the cylinder water.... if this is the case, how do i unblock the coil....
any help appreciated, as my 18 month old baby is currently taking cold baths. and she's not happy!
two questions:
and
