Our hot water is not getting hot enough anymore, we have old gas fired indirect gravity hot water & pumped heating, I think that maybe the heating circuit is robbing the water tank of hot water, The 2 flow pipes from the boiler both go to a connection on the tank & share the expansion pipe. the heating pipe then carries on around the house.
When switching on hot water only it seems the thermostat switches it off before it gets hot enough, however the heating pipe gets very hot where the expansion gravity forces it along parts of the system
does it sound like a blockage in the tank coil/fitting?
Our water is not really hard but our kettle does fur up a little
