hot water not hot enough
25 Aug 2006
Yorkshire
:confused: I am commissioning a BAXI 105 HE combi,a sufficient hot water temp cannot be reached. what are the potential reasons for this?components etc[/i]
Gas rate, flow rate, burner pressure, thermistor resistance, DV passing....????
Its a new boiler, as said , gas rate, then go from there.
Dave.
Water flow-rate exceeding design limit of boiler!
The first question should be: 'is the burner going to the maximum gas rate stated in the spec?' If it is, the heat produced has to be going somewhere!
