Hi guys,
Can you please help me with my boiler problem? I have a Worcester boiler with hot water tank.
- Two weeks ago I turned hot water off (on the control panel set it to OFF) as I did not need the hot water.
- A few days later a plumber came to my house to install a towel rail and move some cold/hot water pipes in the shower area. He put some rubber plugs in my cold water tank on the roof, so there was no need to drain the system. He’s has done the same for the heating expansion tank, when he was doing the towel rail.
- Now (10 days later) I need hot water, but it does not work. When I turn hot water on, the boiler works for 1 minute and then it turns off. If I leave the hot water ON (on the boiler control panel) I can hear some water flow inside the pipes between the boiler and hot water tank, but the boiler is still not working, i.e. no gas is burning inside. And the water does not get warm. I have also noticed that if I leave hot water ON (on the panel) in about 15 Multihead Grundfos pump gets hot.
Any advice please?
Thanks,
Any advice please?
Thanks,
