i wonder if anyone could help out with an extremely annoying intermittent fault that has been on our central heating system for a few months.
basically, every so often, we go through a period of hot water working fine but central heating not. we've got an S-plan system with two 2-port valves. when our CH/hot water comes on, both valves open and the boiler comes on -- therefore the radiators start to heat up. but then, once the hot water has reached temperature, the boiler switches off even if the thermostat isn't at temperature, but the pump seems to keep going. (boiler is a baxi solo HE -- when the fault is present, not even the power light on the boiler is on).
i'm guessing there is some issue with feedback: that the 2-port valve for the CH is feeding back to the boiler that it is closed even when it is open. any ideas what part of the system could be the problem? as it's intermittent, we haven't been able to show the fault a plumber when the fault is actually happening. someone came out a couple of days ago and changed the motor in the CH 2-port valve, but fault was back this morning.
thanks in advance!
thanks in advance!
