hot water on radiators hot ,two 2port actuators operate when hot water called for I thought only the HW should not the CH does this mean I have a program problem(digital) or a duff actuator.
have come to the conclusion that its the timer have checked the pcb and found over heating diode due to poor cct joints and a couple of capacitors loose Iwonder if it has damaged a component looks like a new programmer to be bought
