- Joined
- 18 Sep 2005
- Messages
- 3
- Reaction score
- 0
- Country
just moved into the house 4 weeks ago, apparently the house hadn't been lived in for 6 months. its a gravity fed hot water tank system. no combi boiler, no pump.
turned the hot water on, and no hot water, radiators worked, called the plumber out, said their was a blockage in the cold water tank in the loft, removed and hot water started working.
then after 3 weeks a vibrating noise started, looking in the airen cubboard you can hear the vibrating noise coming from one of the pipes which then disappears into the loft. this vibrating noise only happens when you turn the hot water tap on.
additionally as well as this noise problem, all raditors work apart from the one in the living room, temparature gauage doesn't seem to work and just keeps turning and turning, however when you feel the 2 pipes going into the radiator none of them feel hot, thus i wonder if its a problem with the hot water not reaching the radiator, or is it just simply b'cos the radiators turned off.
any help on either problem greatly appricated.
Daz
Daz
