Hot water pressure/flow
18 Jun 2007
Wolverhampton
I have a hot water tank & immersion heater fed by a cold water tank, the cold tank being 0.8m above the hot tank and 1.2m above the bath taps. The pressure/ flow is very poor. If I moved the cold tank into the loft and gave a drop of about 2.5m to the taps will this improve the flow? Or is there another way of filling the bath quicker?
A better head should give better flow coupled with 22mm hot water feed to bath and reducing to 15mm at sink
Also check that the suite hasn't been changed with flexis or ballofix iso valves installed.
