I have some all electric flats I manage. The hot water is from a direct combination cylinder (400x1050) with a single immersion.
Although the cylinders are mounted on a shelf in a cupboard in each flat, there is only about 1m head. The taps are mixer type and it takes ages to fill a bath and then the water goes cool from the cylinder (so tenants tell me)
There is no boost immersion or timer. I could wire a boost system into the immersion using a time clock/boost switch (immersion at base of cylinder).
My main question is there a pump I could fit to improve the flow rate or would a separate/bigger header tank be needed?
I think unvented or thermal stores would be best, but I am looking for a cheaper solution!
