To cut it short, have bought a house that has a Danesmoor 15/19 oil fired boiler installed - is only 18 months old.
For the first few months we had lovely scalding hot water all the time, but unfortunaltey discovered that this was because the immersion was permanantly on, leading to a HUGE electric bill.
So, turned off the immersion, reasoning that the boiler should be good enough to fill a tank of hot water on its own.
But... it is possible to get it hot, but only without the heating on, and it takes a very long time to get enough for a bath ( even then the water isnt that hot ). Also, when the boiler is set to just run the hot water, the radiators also get hot.
I thought it may be something like a problem with the diverting valve ??? but have looked and cant find one anywhere connected to the pipework ( not really sure what I should be looking for anyway ! ).
Also, there is a thermostat on the side of the immersion tank, but following the wiring, this isnt connected to anything.
So - any clues why the boiler cant make just the hot water come on, and fill the hot water tank reasonably quickly ?
The CH works fine, and the radiators are nice and hot - just need to get some of that hot water to come out of the taps !
If it helps, the system does have a seperate metal tank in the loft, the hot water cylinder is in the airing cupboard.
Any help or advice on what to check much appreciated
Mike
Mike
